LuigiS | How to create a custom material layerLuigiS 2020-08-25 15:12:51 I would like to share a support request: Request: How can I create a custom material layer? Answer: Material Layers can be created and customized in the User/Project BIM Object Library. To create a new Material Layer proceed as follows: 1. open the "USER/PROJECT BIM object library"; 2. from the upper menu choose "material layer"; 3. select the "VERTICAL" or "HORIZONTAL" folder; 4. right click "Append"> "Folder"; ![]() 5. type the name of the folder; 6. select the folder; 7. right click "append" -> "Element"; ![]() 8. in the editor click on "Edit"; ![]() 9. click on the arrows ![]() 10. select the material from the "GENERAL BIM object library". ![]() Once you have finished choosing all the materials for the layers composition, click on “Finish” and then on ![]() Within the editor, in addition to the arrow symbols, we find ![]() • ![]() • ![]() • ![]() Related Videos: Inserting a material layer composition in the graphic tables Related discussions: How to create a customized material to insert in the material layer composition |
