Jigga | bay windowsJigga 2022-02-10 00:13:49 bay window, how to repeat only 5 windows and not 6 as per attached screen shot?262463_1644448409_2022_02_09.png |
Tony | Tony 2022-02-10 09:29:25 Hi Andrew, if you put the window into Edit mode, you can play with the panel auto-repeat parameters so it fits appropriately as a bay-window with 5 panels. I've attached an illustration that shows how to get to those settings, (valid for any window or door type) and a .bol file with the window already created for you. A simple double click will load it into the Edificius BIM Library. Let me know if that works for you. Custom_autorepeating_bay_window Panel_editing_set_dimensions |
Jigga | Jigga 2022-02-10 12:04:01 Thanks Tony, I will try that. Also could you have a look at my other message regarding intersecting roofs, thanks. |
Tony | Tony 2022-02-10 12:34:29 That's Great Andrew! Let me know how that goes. Your other issue was daddressed here: forum.accasoftware.com/en/edificius/id113729/two-roofs-intersecting.html. Regards |
