Forum
morisdidonato
Customizing Layered Assemblies at Intersections
morisdidonato 2026-05-26 16:03:18
The latest release of Edificius v.usBIM(r) introduced a new editor that allows you to customize the visualization of layered assemblies at intersections, by modifying overlap priorities only for the selected intersection.
The general properties assigned to the layered assemblies of envelopes, low walls, and fills remain unchanged.
Operating procedure:
  • Open the Floor Plan Drawing Sheet;
  • From the Properties toolbox on the right, enable the layered assembly display by clicking the relevant checkbox, so that any inconsistencies in the graphical representation of intersections can be identified;
  • Select the floor plan box, i.e. the light blue dashed outline;
  • Click the Edit Layered Assemblies button located in the top ribbon bar;
  • Select the envelope containing the intersection to be modified;
  • Click the Edit Intersections button in the ribbon bar;
  • An editor will open, allowing you to modify the priorities of the two ends.
    The right end is identified on screen as dx, while the left end is identified as sx;
  • Once the modification is complete, click Exit to close the intersection editor, or Restore to return to the initial settings;
  • Close the model editing mode to return to the floor plan view.
