Forum
morisdidonato
External layout in graphic tables
morisdidonato 2026-05-04 12:46:40
I want to share a support request
Request
How can I display the external layout on the roof plan sheet?
Answer
To display the external layout on the roof plan, you can proceed in 2 ways:
Method 1
If you used the Plan object to create the graphic table, you can apply a Section Depth to it so that it reaches the ground.
How to proceed:
  • Go to the graphic table
  • From the properties toolbox on the right, enable the Section Depth
  • Define the Width of the depth.
Method 2
Use the Site Plan object to obtain a top view of the entire model
N.B.:
The procedure described in point 1 can be applied to all plans; for example, in a 3-storey building above ground, I can choose to display the external layout also from intermediate floors.
