Answer The Steel Beam entity can be rotated around its own axis by proceeding as follows:
- Select the Steel Beam entity; - On the right, in the properties toolbox, locate the Geometry section; - To perform a rotation of an angle less than 90°, for example 45°, enter the desired value in the Rotation [°ssdc] field; - To rotate the beam by 90°, choose change… in the Shape field and select the desired orientation.
By accessing and using our website services you implicitly accept the use of cookies to improve navigation and show content in line with your personal preferences. Info OK
