morisdidonato
| Edificius-CAD:User interface customization, workspace, Ribbon, and toolbars. morisdidonato 2025-09-19 10:46:36 I would like to share a support request.
Question Can I create/modify the Edificius-CAD interface to display the commands I use most frequently?
Answer Yes. Customizing the user interface of Edificius-CAD is an excellent way to optimize the workflow and adapt the environment to your needs.
First of all, it is necessary to distinguish the 4 concepts in question.
- User Interface (UI)
The user interface is the complete set of visual and functional elements that allow you to interact with the software. Includes: Ribbon, Toolbars, Drop-down menus, Palettes, Status bar, Command window, Layout and model tabs. In practice, it is everything visible in the program window.
- Workspace
A workspace is a configuration of the user interface that includes: Toolbars, Menus, Palettes, Ribbon, Specific commands. Each workspace is designed to simplify the work depending on the type of drawing you are doing. In Edificius-CAD the following workspaces are available: Drafting & Annotation: Optimized for 2D drawings, with dimensioning, text, and layer tools. Classic: Traditional interface with floating toolbars and drop-down menus. View and Markup: A workspace dedicated to reviewing, annotating, and viewing drawings. Very useful in collaboration, approval, or quality control contexts. Custom: Created by the user, with manually chosen layout and tools.
- The Ribbon, or multifunction bar, is a user interface element that makes access to commands more intuitive and organized.
It groups related commands together (for example, in Annotate you will find Text, Dimensioning tools, etc.).
- The Toolbar, instead, is a graphical interface that collects commands, improving efficiency and productivity in technical drawing (for example, the Draw toolbar includes line, polyline, spline,...).
Customize User Interface (CUI) Edificius-CAD provides an editor to modify workspaces, menus, toolbars, ribbons, and commands. You can access this editor in several ways:
- By typing _CUSTOMIZE in the command bar;
- By right-clicking on the ribbon at the top and selecting the Customize option;
- From the “workspace” menu located in the title bar, again choosing the Customize command in the drop-down menu;
- Etc.
Here are some examples of customization a. Hide a function from a Menu (obviously active and positioned in the user interface) From the Current Customization drop-down menu on the left, you can choose the entity to modify and, from the Properties panel on the right, set False for visibility.
b. Create/rename/copy/delete a workspace Just right-click on Workspace.
c. Create a toolbar In ICAD >> Toolbars >> right-click.
d. Add a command to a toolbar - Locate the toolbar in Current Customization; - Choose the command in Command list; - Drag it to the chosen toolbar.
N.B. The operation is similar for all CAD software. You can always access the Edificius-CAD help by pressing the F1 key on the keyboard. |
