How to remove the dimensions of openings from the floor plan
morisdidonato2025-09-16 15:41:23
I want to share a support request
Request How can I remove the dimensions of openings from the floor plan?
Answer To remove the dimensions of openings (doors, windows, and holes) from the drawings (floor plans), proceed as follows: - Open the Graphic Sheet - Floor Plan; - Click the Styles button located on the ribbon at the top; - Select Edit...; - Open the layer group of the opening to customize (Door/Window/Hole); - Deactivate the "Dimensions" layer in NON-SECTIONED parts.
By accessing and using our website services you implicitly accept the use of cookies to improve navigation and show content in line with your personal preferences. Info OK
