Forum
Helping others, engage in discussions, share your experiences and knowledge with other users.
User_1116300
Edit Properties
User_1116300 2020-05-12 09:04:07
Hi,
The Edit Properties button isn't shown in the menu bar. Does that depend on whether the model is editable or what other possible reason could there be?
Thanks!
Tony
Tony 2020-05-12 11:57:17
Hi,
the Edit function is enabled when you click on the Modl or entities contained in the Model. There's no particular level of permission to put the IFC model in Edit mode.
Let me know how it goes.
Tony
Tony 2020-05-12 14:46:45
HI, BEFORE WE CONNECT, LET'S CHECK A FEW THINGS.
In some cases, the software will block the Edit feature due to duplicated PSets or other similar problems (often occurs with Revit IFCs)...
Maybe you can send us your file so we check ??
Tony
Tony 2020-10-21 16:10:14
Hi!...
That seems to be the case from what I can see in your Screenshot.
Would you like to send me your file so I can see if we can "unlock" those entities.
Regards
Tony
Tony 2020-10-22 17:51:23
Sure, send it to:
tony.depalma@accasoftware.com
Tony
Tony 2020-10-23 14:04:44
Hi Virginija,
I've attached a modified version of the IFC file - Please check your email inbox.
You should find everything ready to be edited in terms of properties.
The main issue in your file was that most entities had duplicated IDs and therefore causing conflicts. This depends on the software used to export the IFC model so please be careful that the IDs are Unique.
Regards
