Patricio | How to export models in the IFC formatPatricio 2021-10-06 09:06:18 echnical support query discussion Request I need to export my 3D model as an IFC file - is there a special feature for this? Answer Yes, you can export your 3D model in the IFC format, by following these easy steps: - go to a workspace level or the 3D view of your model; - from the toolbar select the Export in IFC command. see image ---> "Export in IFC" (toolbar) Then choose the file path and name. The IFC export command is also available in the File menu: - selected the level or the 3D view of the model; - from the File menu select Export; - click the IFC Format option. see image ---> IFC format (File menu) WARNING The above is valid both for the BIM MODEL and IFC editor environments. |
