TonyC | Save with output - Open with outputTonyC 2021-06-14 14:42:29 I would like to share a support case Question I have opened a file in TerMus-Plus with a calculation already performed. I cancelled the calculation, made some changes but then closed the file without saving. Upon reopening, the same file was NO longer in the calculation state. Is there a reason for that? Answer When a calculated file is opened, any reset involves deleting the database which is NO longer recoverable. To preserve the calculation results, it is preferable to perform the operation as "Save as Output" when saving. Click here to see how to perform the "Save as Output" from the program Home page. Click here to see how to access the program Home page section. A file saved in this mode has the extension ".Tme+so" Once saved, opening the same file must be performed in the "Open with Output" mode. Clearly, in the "Open with output" mode, any files with the ".tme+so" extension must be specified. Click here to see how to run "Open with Output" from the program's Home page. Closing without saving an open file in "Open with output" mode does not modify the ".tme+so" file which will always show the calculation performed in subsequent reopenings. |
