TonyC | Fatal Error [1017]: Room not assigned to zoneTonyC 2021-06-11 10:19:19 Technical support request Request: I have performed the analysis procedure but I get the Fatal Error Message. How can I correct it? Answer This message means that a Room has been created but is not assigned to any heating zones and therefore cannot be calculated. To correct the error, select the room and choose the zone using the window on the right (inspector panel) in the Units and Zones section. (see image) |
