Forum
TonyC
How to define the boundary with the terrain
TonyC 2021-06-10 15:21:33
Here's a Technical support ticket that was sent by one of our users
Question
How can I define the boundary with the terrain?
Answer
There are 2 ways to define the terrain:
a) select the wall and in the properties toolbox on the right, in the Border section select the Land check (see image). In this case, the whole wall will be considered as against the ground.
b) Using the wall basement wall object. This second option is necessary when the wall is partially under-ground (see image ). If the wall is completely buried, the two methods are equivalent.
