How do I insert a device in the "Consumption" analysis section to represent a hypothetical average monthly consumption rate?
Victor2018-06-04 12:29:55
Here's another technical support issue that I wanted to share with our users
Answer Let's insert a possible average monthly consumption by adding a new device and defining the relating consumption rate as "June Consumption". Here's the step by step procedure described below. Example: Monthly consumption 300 kwh - Daily consumption 9.67 kWh (monthly consumption/31 days) - Consumption Timetable 0.403 kWh (Daily consumption/24 hours)
1] Go back to the Consumption node and add a new device;
2] define device specifications, assigning only the reference month in terms of consumption;
3] enter the daily hourly consumption rate from 0:00 to 23:00, by setting it to 0,403 kWh
4] you'll now see the estimated monthly consumption rate value
Using this basic procedure, other device's can be considered too.
For further details regarding this topic, have a look a the following video:
By accessing and using our website services you implicitly accept the use of cookies to improve navigation and show content in line with your personal preferences. Info OK
