Forum
Helping others, engage in discussions, share your experiences and knowledge with other users.
Héctor
Battery only inverter
Héctor 2021-06-08 03:37:34
Is there a way in Solarius PV to add inverters without PV modules and use them just for storage in batteries?
Tony
Tony 2021-06-08 08:57:49
Hi,
No, you can't insert ony the Inverters because their presence and sizing aspects are part of a step by step design process which requires you to insert the Modules too. On the basis of the installed Power, determined by the type and number of modules, the Inverter type, and of course their number, can then be defined.
Hope this helps
