Antony | How can I view the file saving path when printing my BoQ documents?Antony 2020-10-19 15:48:16 Technical support case Request I need to print my documents with the document save path. Is there a way of doing this? Answer In order to insert file name and path on the last page of the report , you need to enable this function by flagging the “print document filename” option available in the General page under the print settings tab. -> please check the attached image |
