Antony | How to manage rounding (decimals, etc.) when importing a document from Excel.Antony 2020-10-19 15:03:57 Request How you can manage value rounding (approximation, decimal, etc.) when importing a document from Excel Answer An Excel file obtained by exporting a PriMus document when it is reimported is based on the default configuration of the document that is currently xset in the software. But if you need to change those settings, : 1) create a new document; 2) customize the number fields configuration according to your needs; 3) select the 'Save Configuration (Default) so that the software acquires the customizations and sets them as default for each new document that will be generated from that moment onwards -> see Figure 4) close the document without saving; 5) import the Excel file. |
