Antony | How to acquire the reinforcement rebars weight information (table values)Antony 2020-09-22 17:42:11 I'd like to share another technical support request with our PriMus users Request How can I get the rebars weight data without having to type it in manually in each measurement row ? Answer The rebar weights can be acquired from the "Rebar weights" table. In fact, when adding a measurement row that refers to the reinforcement bars used in reinforced concrete elements, you can insert the Ø symbol (press the "#" key) in the measurement row's description field followed by the rebar diameter value expressed in millimetres. You'll notice that the rebar unit weight per linear meter is inserted automatically calling up the corresponding value from the "Rebar weights" table in the H/Weight field. The quantity field will show the total weight in Kg. --> click here to watch the video tutorial: How to get the rebars weight data in each measurement row |
