Forum
Antony
How to activate the fields to insert measurements
Antony 2020-08-24 16:59:55
Here's a technical support case that I'm sharing with our priMus users
Request
How can I activate the fields to insert measurements?
Answer
If the measurements fields are not visible, it is likely that the settings of the Dimensions columns (eq.parts, length, width and H/weight), i.e. those in which values can be edited, have been removed from visibility in the Measurements editor view of the document.
It is useful to remember that to insert a total quantity, this value must be entered in the 'eq. parts' field, as the 'Quantity' field is NOT editable (being a calculated field).
In your case, therefore, you must make visible at least the 'eq.parts' columns --> see figure.
Note - from the General page of the BoQ print settings, choosing Print Total ONLY option won't display the 'DIMENSIONS' columns in the printout.
