Antony | How to indicate the amount directly for each itemAntony 2020-07-13 15:12:40 Here is another support case. Richiesta How can you insert the amount directly for each work type? Risposta Normally the amount of each cost estimate item is determined by means of the product [ QT x Unit Price] --> see figure If you need to indicate the amount directly for each item, then you need to operate in the following way: 1) from the document's Price List editor, insert the amount in the 'Rate [1]' field for each item --> see figure 2) from the document's Measurements editor, type in the value 1,00 for each estimated item in the field 'par.ug.' --> see figure |
