How to export the Financial Table in an editable format
Antony2020-06-16 16:54:12
Here is a technical support case that I'd like to share with our users
Richiesta How can you export the Financial Table in a format that is editable by a text editor?
Risposta To achieve that, you can use the export in RTF function from the Print settings. When exporting in RTF format, you obtain a file that is editable by any text editor, such as Microsoft Word.
PROCEDURE: 1.access the Print editor 2.select, for example, the Bill of Quantities node; 3.set up the print Financial Table option from the General section; 4.then select the link Export… (on the bottom right-hand side of the page); 5.select export this print as RTF file.
By accessing and using our website services you implicitly accept the use of cookies to improve navigation and show content in line with your personal preferences. Info OK
