Antony
| How to add new tables in the software archive and obtain the respective values (weight, etc.) in the measurement rowsAntony 2020-06-08 16:56:50 Here's another really interesting technical support case QUESTION How can I add new formula tables in the software archive and get the relating values when called up in a measurement row (weights, etc.)? ANSWER In the software archive, you'll find the following tables with their respective values: 1) Rebar 2) L-beams with equal sides 3) Double-T beams 4) L-beams with unequal sides 5) Circular section tubes 6) Square section tubes 7) Rectangular section tubes --> see figure Nota - these tables can be edited and/or integrated by accessing the page 'Weights tables' from the 'PROGRAM Options' window. --> see figure Additional tables (with their respective values) that can be added --> see figure Note - importing tables and/or values from other formats is not a possibility provided. Relating video tutorial: --> Customizing the program (the topic 'values in the table' is dealt with at the minute 01:01 and 01:21) Note - although the tutorial has been produced with a previous software version is still valid to understand the use of the window Options PROGRAM. |
