Forum
Antony
How to add text wrapping in the financial analysis document
Antony 2019-10-01 17:37:40
This technical support issue was sent in by one of our users
REQUEST
How can I wrap the text in the financial table?
ANSWER
In the financial table you can't re-order text with text wraping.
If your text exceeds the page margins it will automatically add a return to the following line
-> see the attached image
If you need to wrap a text (for example: to create a bullet point, etc.), you need to use multiple lines
- > see the attached image
To edit the text within a line consider enlarging the text input field with the 'Crtl + Enter' key combination -> see the attached image
