Felix | Composite Work types (Rate Analysis)Felix 2015-03-05 09:23:51 Here's a new technical support issue that I wanted to share QUESTION How do I specify the resources in a Rate item REPLY To specify the resources composing a singe rate (materials, transport, hired equipment, etc) simply use the Rate Analysis feature already available in PriMus Free UPP. The Rate Analysis feature allows you to calculate the Unit Rate by simply indicating the individual quantities and unit rates that for each resource that composes the Rate itself. Access the following link to see how to calculate the unit rates using the Rate Analysis feature video.accasoftware.com/EN/primus/id69/index.html?idPLV=11006&autoplay=1 video.accasoftware.com/EN/primus/id69/index.html?idPLV=11005&autoplay=1 video.accasoftware.com/EN/primus/id69/index.html?idPLV=11004&autoplay=1 Access the following link to download an example file for PriMus Free UPP example_boq_rate_analysis.dcf Click the following links to download the individual documents that can be obtained from the example file: 01_boq_rate_analysis.pdf 02_boq_requirements.pdf 03_boq_price_list.pdf 04_boq_bill_of_quantities.pdf 05_boq_bill_of_quantities_with_analysis.pdf 06_boq_works_estimate.pdf 07_boq_works_estimate_with_analysis.pdf 08_boq_list_of_work_and_supply_categories_with_analysis.pdf 09_boq_list_of_work_and_supply_categories.pdf |
