Antony | How to insert only the Quantity data in the measurement rowsAntony 2018-10-23 18:33:35 Technical support issue QUESTION For some job items that I have accounted for, I only need to specify the total quantity without having to show the individual measurements (Length, Width, Height) How Can I insert a direct total measurement seeing that I can't edit the "Quantity" field ANSWER Yes, infact you can't because this field shows the result of a multiplication between the [Eq.parts] - [leng.] - [width] - [H/weight] fields. In this case, all you need to do is insert the Total quantity value in the 'Eq.parts' field and confirm each of the following dimension fields with Enter [^]]--> see figure Of course, when moving on to printing you'll see the same quantity value in the 'Eq.parts' field - [^]]--> see figure |
