Forum
Antony
How to protect a document from changes
Antony 2018-10-23 18:12:38
Here's a Technical Support case that I wanted to share with our users
Request
How can avoid unwanted modifications on a PriMus project?
Answer
In order to avoid unwanted modifications, you should enable the password function by inserting a password in 'Change Read and write Password' in the Password page under the General Data section of the document that you want to protect from changes -> see attached image
The next time the document is opened, it will prompt the user to insert the password enabling changes, otherwise the document can be used only in 'Read-Only mode ' -> see attached image
