Forum
Antony
'Move Measurement Item' option disabled
Antony 2018-06-19 16:47:58
Here's a technical support case sent by one of our PriMus users
QUESTION
Why is the "Move Measurement Item" option disabled?
ANSWER
The 'Move measurement item...' button is turned off (gray) when the item to be moved is selected (shown in red text) ---> see Figure
HOW TO PROCEED
1) select the item to be moved in the Measurements editor;
2) call up the function 'Move measurement item...';
the item to move is shown in red and selected.
3) move the cursor up or down to choose the new item position;
4) select the button to confirm the movement.
---> see Figure
If the option 'Move measurement item...' isn't active, this means that the entries in the Measurements editor are ordered by Rate and not by Order number ---> see Figure
To use the function 'Move measurement item...' simply select Order number for item ordering ---> see Figure
Note- remember that item sorting is proposed by default by the software in the Measurements editor
