Here's a technical support request sent by one of our PriMus users.
Question
How can I modify a Supercategory or simply delete it?
Answer
To modify and/or delete a Works 'Category' (Common Arrangement of Work Sections) you need to: 1) Access the 'Chapters and Categories' section under General Data; 2) Select the 'Category' to modify (Super Category, Category or SubCategory); 3) Select the row that contains the category description and after having selected the row, simply press the 'Ctrl + Del' keys to delete it.
Note - this procedure is valid for the varuious levels of Chapters too
This feature has been disabled with regard to modifying multiple Price List items at once. However, you can re-assign items to specific Chapters/WBS structure manually.
By accessing and using our website services you implicitly accept the use of cookies to improve navigation and show content in line with your personal preferences. Info OK
