Antony | How do I change the font size and column widths in my printoutsAntony 2018-04-16 18:25:49 Here's another Technical Support case for our PriMus users QUESTION How can I change the font size and column widths when preparing my estimate for printing? ANSWER 1) To access the print settings (margins, sheet layout, font, font size, etc.) simply go to the PRINT SETTINGS section that appears when pressing the PRINT button. --> see figure 2) Column size is varied according to the maximum number of whole and decimal digits that it can contain. This setting can be adjusted during document configuration. PROCEDURE: 1) access the 'General Data' editor; 2) access the 'Configuration' section uder the 'Configuration' tab; 3) change the configuration of the desired column, increasing or decreasing the number of digits of the integers and/or decimals. --> see figure The width of the first column (Ord. nr. and Tariff) can be changed in the Various and Signatures dialogue under Print Settings. --> see figure Note - the increase/decrease of these column sizes will affect the amount of space available for the "Description" column (second from the left). |
