Antony | How to modify the size of the image loaded in measurements rowsAntony 2017-08-29 18:46:21 I would like to share a request for assistance Request What is the procedure to enlarge an image associated to measurements rows? Answer In order to enlarge/reduce an image associated to a measurement row (or to a 'Price list' editor item), you need to increase/decrease the value of the 'Percentage' field in the OBJECT PROPERTIES dialog--> (see explanatory image) Note –by using the percentage value you indicate how much of the document printable surface the image has to occupy; this value allows you to resize the image in both the document views and the print documents. |
