Antony | How to assign references to items in order to easily find them: BookmarksAntony 2017-08-29 17:20:33 I would like to share a request for assistance Request Good morning, I have a question: I inserted some 'Bookmarks'. However, I have noticed that, when closing and reopeningthe document, I cannot find them anymore. Might it be the case that I am not properly using them? Answer Bookmarks can be used according to two usage modes: 1) “temporary” mode: a marker to be used for the work session only. It aims at facilitating the currently executed operations. Therefore, when the document is closed, this marker is removed --> (see explanatory image). 2) “permanent” mode: a marker you insert in the measurements rows and, when the document is closed, it is not removed --> (see explanatory image). In order to find the items containing it, you need to: - use the 'Select object to browse' feature arrows --> (see explanatory image); ...or - use the arrows after selecting the Bookmark' optionof the 'Super Search in current view' in the 'Find'toolbox --> (see explanatory image) |
