Felix | How to remove the '<none>' title when printing the 'Categories Structural Summary'Felix 2016-08-24 10:07:53 Here's an interesting technical support case Request Why is it that when I print the 'Categories Structural Summary' page of the bill of quantities, it comes out with a title saying '<none>'? (See image) Is there a way of removing that annoying '<none>' title when printing my documents? Answer This happens when one or more items aren't assigned to a 'Category' (Super Category, Category or Sub Category). To get rid of the '<none>' title in the 'Structural Summary' make sure that all items are assigned to a 'Category' (Super Category, Category or Sub Category). HOW TO PROCEED #1 - enable filtering of '<none>' in the ' structure ' toolbox 1) access to the 'Measurements' editor; 2) open the ' structure ' toolbox; 3) select the sort by 'Super Categories' method; 4) do a right mouse button click on '<none>'; 5) select 'Activate Filter'; #2 - assign the highlighted items to their relating work categories 6) highlight the resulting measurement items after activating the filter on '<none>'; How to highlight items : a) to highlight and select measurement items, simply proceed with the following keyboard combination: ' Shift '+' Ctrl '+' E '; b) to highlight single items, use this combination: keep the ' Shift ' key pressed + 'keyboard Left Mouse button Click ' on the items you wish to highlight. 7) 'Right mouse button click' on an entry to open the local menu; 8) activate ' Edit selection block...'; 9) select 'Super Categories'; 10) choose the approriate 'TITLE' from the combo box; 11) click 'OK' to execute the command and close the dialog; 12) to access the 'Print' editor; IMPORTANT !!! Repeat the procedure from point 3) to the point 11) after you apply the filter on <none> present in the 'Categories grouping ' (see illustration) and then in the 'Sub Categories' grouping (see illustration). #3 - Printing the work categories structural summary 13) select the 'Cost Estimate' document; 14) open the 'Categories' page under print settings; 15) select 'Work categories structural summary'. Click HERE to see a detailed illustration of the entire procedure |
