Forum
Mauro
Selecting IFC entities in the tree navigator
Mauro 2020-08-26 15:08:11
Technical support case
Request
Is there a way to select the IFC entities in the Entity navigator on the left.
Answer
To select the IFC entities, in any kind of order, just do a left mouse click on the first entity and then select the following ones while holding down the the CTRL key.
If you need to select a group of entities contiguous to each other do the same thing as described above but using the SHIFT key.
