Forum
Mauro
Viewing the IFC entity Properties
Mauro 2017-05-31 10:00:58
Here's another technical support issue that I wanted to share with our Users
REQUEST
I can't seem to view the IFC entity properties.
How doI proceed in these cases?
ANSWER
The IFC property data are embedded with the object itself.
If you can't view any data, or it seems to be missing, it means there's no data assigned to the IFC entity. All you can do is make sure that when you export such entity types from an external appliaction, data export is enabled and that no filters are applied.
If on the other hand, you are sure that the data is present, but can't view it, try following this easy procedure as described in the following video:
video.accasoftware.com/EN/primus-ifc/id448/index.html?idPLV=8434&autoplay=1
