TonyC | How to transform the 'Design Stage' situation to a 'Surveyed' stageTonyC 2019-10-17 09:17:32 Here’s a new technical support case that has been addressed various times by our users QUESTION Is there a way of converting a model defined as a "Design Stage" document to a "Surveyed Stage" file so as to calculate the seismic vulnerability of the building before construction? ANSWER If you need to convert a "Design Stage" file to a "Surveyed stage" file, simply follow these few simple steps: 1) cancel any previous calculations that may have been launched by pressing the Reset Calculation button; 2) Open the Calculation Preferences in the Project in NAVIGATOR by doing a double-click on the node; 3) Open the Existing Buildings sheet; 4) click within the Situation field on the relating button; 5) click Yes, in the WARNING window in order to proceed with the conversion process; 6) now simply Save as to change the document status from “Design” to “Survey”. Click the link to see a detailed illustration of the procedure: Design Stage -> Current Situation |
