TonyC | How to modify and customize Column reinforcementsTonyC 2015-02-27 17:19:49 Here's another technical support request that was put forward by one of our EdiLus users REQUEST I need to add and customize the calculated reinforcements in a column and therefore modify the number of rebars and their diameters. How do I proceed? ANSWER: To modify the Column reinforcements calculated by EdiLus, proceed as follows: - select the column and view its reinforcements; - select the "Corner Rebars" description to modify the diameters in the properties toolbox; - select the longitudinal rebars or the coloured bands to modify number, diameters and number of reinforcement layers; - select the Links or stirrups to change the diameter in the properties toolbox; - now press the Confirm button to run a resistance check based on the newly modified reinforcements. Click here to see a short video that shows how easy it is to customize the reinforcements in a column: video.accasoftware.com/EN/edilus/id342/index.html?idPLV=6234&autoplay=1 To view column reinforcements, you can proceeds in two ways. Method 1: - select the column - by activating the local menu, with a right mouse button click, select View Reinforcements in the "View" field. Method 2: - access the Navigator's "Reinforcements" node - with a double click on Columns - select Column Grid |
