Forum
Mechanicos
Define New Materials or Edit existing material properties
Mechanicos 2017-06-01 20:36:12
Hi,
Is it possible to define a new material in Edilus or is it possible to edit existing material properties?
For example i want to change the Youngs Modulus of a a beam, is that possible
Regards
TonyC
TonyC 2017-06-05 09:28:27
Yes, you can add new materials to the archive and modify characteristics accordingly.
Proceed as follows:
- open the Elements node in the navigator.
- select the Materials sub-node.
Select the materials folder to add or modify. To add a new material simply do a right click on the folder and add the new material type.
