TonyC | How to modify the rebar diameters tableTonyC 2017-02-03 12:26:24 I'm opening this new thread to share a technical support case. QUESTION: How can I change the rebar diameters table to be able to add extra diameters used in my country? ANSWER: You can change the diameters in the table and choose those used in your country as follows: 1) open the Calculation Preferences with a double click; 2) select Reinforced Concrete ; 3) in Current Table select the desired item; 4) click Confirm. Click HERE to see an ilustration of the step by step procedure. N.B.: To be able to access this section of the program, be sure to have done a calculation reset. |
