Stream read error importing from dxf/dwg CAD drawing
TonyC2015-10-22 12:00:24
I'm sharing another interesting technical support case with our users
REQUEST Importing a DXF/DWG CAD file I get the following error message: "Stream read error". How can I solve this kind of problem?
ANSWER This sort of problem may depend on two possible causes
Cause 1 The TeighaX component (used by EdiLus for importing dxf/dwg files) may not be correctly installed.
A possible solution could be to re-install the TeighX component as follows 1) close EdiLus and other CAd applications; 2) open the .Common folder under the ACCA install folder (normally: C:\ACCA\.Common) 3) open TeighaX 4) double click TeighaX_vc10dll.msi to launch the install process and follow the on screen instructions to the end. 5) Once "TeighaX_vc10dll.msi" is re-installed, re-launch EdiLus and try importing a dxf/dwg file again (we suggest trying with "Example_01.DWG" which can be found in the "Examples" folder).
Cause 2 The DXF/DWG CAD file that you are trying to import may contain external references to images or other links. In these cases, to resolve the problem: 1) open the DXF/DWG with your own CAD software; 2) delete any references to external images or elements; 3) now save the DXF/DWG file choosing the 2007 or 2010 or 2018 file format and close your CAD; 4) now re-import this newly saved CAD file into EdiLus.
N.B.: In general, it's best to explode all internal Blocks contained in the DXF/DWG to import and cleaned from any elements that are un-necessary for building up your structure in EdiLus (such as blocks, 2D objects, 3D, hatch patterns, etc.).
By accessing and using our website services you implicitly accept the use of cookies to improve navigation and show content in line with your personal preferences. Info OK
