TonyC | Inserting pitched slabsTonyC 2015-05-29 17:56:31 Another interesting Technical support issue that I wanted to share with our Users Question: I need to insert a sloped slab at roof level. How do I proceed? Answer: To insert a sloped slab you can use the "automatic" recognition feature but keep in mind that in some cases this may result to be difficult or the slab may not be inserted correctly. In these cases simply switch to "Manual". Here's how to proceed: - select the slab that has the "in error" label or that seems to lay incorrectly; - change the recognition method to "manual" in the slab properties; - specify the slab's plane by placing the 3 points that indicate the desired plane. Click here to see how it's done: video.accasoftware.com/EN/edilus/id378/index.html?idPLV=8847&autoplay=1 |
