John | Setting up the site for a correct shadow analysis simulationJohn 2015-05-11 10:51:41 This interesting case was put through to our Forum by our users QUESTION: is there a way of geo-locating the building site so as to simulate and analyze projected shadows? ANSWER: to set up the site's coordinates simply input the values in the specific geo-location fields as described: - open the Project Navigator's General Data node; - type in the site's latitude and longitude data; Then correctly set the North direction to get the most accurate results; Now all you need to do is set the time of the day in the "Shadows" box. |
User_614509 | User_614509 2015-08-06 15:56:13 Hi, How do I set or correct the North direction in an existing project? cheers Jon |
Patricio | Patricio 2015-08-06 18:55:22 On a project level, once you have selected the Orientation symbol, you can rotate it with the provided handles, defining in this way a different orientation. In the attached image the orientation symbol. north.png |
