Forum
AdrianaZ
Beams legend and beams numbering on floor plan
AdrianaZ 2020-09-22 13:00:35
This support ticket was sent in by one of our users
Request:
I need to show the beam numbering sequence as shown in the legend? Is there a way to do that?
Answer:
Yes you can actually, try this:
1. to create a Beams legend, select the "OBJECTS legend" option from the “drawing menu”;
2. to customize the information shown in the table columns, choose the variables relating to the Beam properties (click the “variables” option and choose the desired property);
3. insert the “Legend object” on the floor plan;
4. you can also customize the table by setting up a filter. To customize the filter: select the table and choose the properties to be shown in the properties toolbox;
5. In order to show the numbering sequence next to each beam of the floor plan, a "Label" object must be inserted for each object;
