LuigiS | How the window position changes in relation to the editing of envelope dimensionLuigiS 2020-08-25 16:06:17 I like to share a support request: Request: How does the position of a frame change when I modify the length of the in which is inserted on? Answer: To understand the effect of a lengthening/shortening of an "Envelope" with regard to the position of a "Window", it must be taken in consideration that: - the "Starting Point (P1)" of the envelope is the rear end of the arrow marked on it; - the "End Point (P2)" of the envelope is the front end of the arrow. ![]() A shift of the Envelope End Point implies that: - the distance between the Start Point and the window remains unchanged. - the distance between the End Point and the window varies by the same amount as the displacement. A shift of the Starting Point implies that: - the window follows the Starting Point of the envelope, so the distance between the two points remains unchanged; - the distance between the End Point and the window varies by the same amount as the displacement. In this case, the window follows the envelope displacement. Related Videos: The envelope design |
