AdrianaZ | Rendering Settings: OUTPUTAdrianaZ 2020-08-25 10:08:33 To access the OUTPUT window simply start the rendering process. You can also read this forum discussion describing how to operate: how-to-proceed-with-renderings.html The Rendering Settings also allows you to choose between: 1. Type of Render Image, 360° VR Panorama or 360° Stereoscopic Panorama; - the 360° VR (virtual Reality) panorama shows a wide visual angle view of the model; - the 360° Stereoscopic panorama returns a three-dimensional view of the visual field; 2. the pixel dimensions of the rendered image; 3. the dimensions in millimeters if the render is to be printed; ![]() Read also how In the Render Settings BACKGROUND window choose: - Color: when you want to use a monochrome color as a background; - Sky: when you want to use the sky as a background, with its horizon line; - 360 ° VR image: when you want to use a 360 ° spherical image (also customized) as background; - Transparent: when we want to leave the background transparent to subsequently insert a filling (to be carried out with external software); ![]() ![]() |
