Forum
LuigiS
walls traces in the horizontal envelope
LuigiS 2020-07-20 09:12:03
I would like to share a support request
Inquiry:
What can I do in order to not visualize the walls traces from the underlying level on the level where I’m working on
Answer:
In Edificius, as default the walls has the height of the level on which they were designed.
If you don’t like to visualize the wall traces from the floor below, you can proceed in the following way:
- insert the room object in the rooms;
- lower the internal envelopes of the building by assigning a "delta" from the properties toolbox in "height reference system" > "Upper"
Related Videos:
Drawing the Building Envelope
