LuigiS | Modeling a roundaboutLuigiS 2020-07-09 14:08:58 I would like to share a support request: Request: How can I model a roundabout with Edificious? Answer: Once in the Edificus Terrain environment of proceed as follows: 1. in the "00 survey" level draw the terrain perimeter; 2. in the "01 Project" level, draw a triangular yard; 3. select the yard sides and use the "Edit" button on the ribbon to select "convert in arc". now the yard has a circular shape; ![]() 4. on level "01 Project" draw the roads (object "Road") that intersect the roundabout; 5. on the same level, model the central part of the yard by inserting two circular walls ("wall on the ground"); 6. in the "02 Project" level with the "earthwork" object model the ground between the walls; 7. in the "03 project" level it is possible to draw a new earthwork, with a different height, to which we will also add the slope to create a relief effect. ![]() To help modeling the yard or earthwork, 2D graphics objects such as "parallel guide line", "circumference", "line" etc. can also be used. Related Videos: Drawing a yard The Earth Works properties Example files are attached: Example file Rotonda |
