LuigiS | How to insert a window on a staircase wallLuigiS 2020-06-09 17:26:34 Problem: I need to model a window and fit it on top of a staircase wall. What's the best method ? Answer: To insert the window on the staircase wall, use the "curtain wall" object. Follow this simple procedure: - draw the curtain wall in the level from which the staircase starts; - in the 3D view, using the snaps, bring the entity to the desired level and height; - in the properties toolbox assign the upper/lower right/left offsets ![]() - Within the facade editor, decide the kind of framing repetition, as described in the following forum discussion: Frame repeating ![]() ![]() ![]() related forum discussion: Windows on staircases |
