LuigiS | Full height window for a StaircaseLuigiS 2020-06-04 14:34:21 Question: How can I insert a full height window on the wall of a staircase Answer: This type of setting for a window object can be achieved as follows: - draw the wall building envelope delimiting the staircase. Start from the level from where the wall raises, for example: the Ground floor. - in 3D view, using snaps or assigning the level, raise the wall up to the desired height; - insert the window (Fixed window) in the casing, enter the correct measurements or use the snap points to bring the entity to the desired height; When using a frame model with a certain repetition (horizontal/vertical) you can also change the repetition step as described in the following forum discussion: Frame repetition ![]() ![]() ![]() Other Related forum thread: How to insert a glass wall on the wall of the stairwell Related video Stairwell window |
