AdrianaZ | Floor area net of the staircaseAdrianaZ 2019-09-30 16:28:50 Here's a technical support issue that was sent by one of our users Question: How can I reduce the area relating to the open staircase from the total area of the ROOM. Answer: To calculate the surface of the ROOM net of the staircase surface you can close the perimeter using the dummy wall object. ![]() Note - Edificius can detect rooms and compartment subdivisions when the following partition type objects are used: Vertical Envelope, Curtain window and the Dummy envelope that are used as a perimetral contour to a determined surface. Watch this video --> How to define a dummy envelope Corelated discussions: --> How to insert an opening in a slab for a staircase |
