Forum
John
Transfering the USER BIM OBJECTS LIBRARY from one PC to another
John 2015-03-03 12:51:45
Here's an interesting technical support case that I wanted to share with our users
QUESTION:
How can I transfer my USER BIM OBJECTS LIBRARY, created with Edificius on one PC to a different PC
REPLY
the USER BIM OBJECTS LIBRARY is contained in "Edificius-UT.IT.CTLG2" which is in folder "C:\ACCA\Edificius\Resources\IT\Data".
To transfer the BIM OBJECTS LIBRARY to a different PC you need to:
- copy "Edificius-UT.IT.CTLG2" from the source PC;
- paste it in the "C:\ACCA\Edificius\Resources\EN\Data" folder replacing the original file present in the same folder on your destination PC;
WARNING!!!
With this operation the BIM OBJECTS LIBRARY already present in your destination PC will be overwritten with the BIM OBJECTS LIBRARY copied from the source PC, therefore, all the elements contained in the destination PC USER BIM OBJECTS LIBRARY will be lost.
