Maurice | DXF/DWG import: I get the Interface not registered messageMaurice 2018-11-19 17:47:21 I'm using Edificius and I import a DXF/DWG CAD file I get the following message: Interface not registered Solution: This problem is quite often caused by a bad installation of the (Teigha) component used by Edificius for DXF/DWG file format import/export. This means that the component needs to be repaired or re-installed as follows: How to proceed: - with Windows Explorer, go to the: "C:\ACCA\.Common" folder; - open the " TeighaX_x64 " folder; - double click on the file: "TeighaX_vc10_amd64dll.msi"; - from hereon, simply follow the installation to install or repair. At the end of the procedure, restart your PC. |
Tony | Tony 2022-05-04 10:21:01 Can you please send in your CAD file so I can check? For file privacy reasons please use our support service: support.accasoftware.com/en/edificius adding reference to this ticket: id=99785 Thanks |
